1981 Corvette: Replacing Power Steering Hoses
Submitted by: Scott81
The hoses are pretty easy to change. First step is jack up the Vette and get it level on 4 stands. Take off the front wheel then using a line wrench (please use a line wrench, it will be SO much easier and will require a minimum of swearing) take off the old hoses.
I would recommend taking off the control valve and assist and putting the new hoses on before you put everything back together, it's easier and you won't end up stripping any threads on the assist arm. While everything is out you may want to run some fluid through the pump to flush it out.
The most important step is to make sure you put the hoses on in the correct way, otherwise when you get it together and start it up your steering wheel may turn into a propeller.
For bleeding, leave the car in the air, add fluid...put the cap on and start it up. Then turn the steering wheel back and forth about 10-15 times. Make sure you turn it each way until it stops. If the wheel feels jerky after bleeding you might need to adjust the control valve. I'll write that if you need it.
Let me know if you need better directions, I can even go out to the garage and get digital pics if you need.
DISCLAIMER:  This How-To article contains information from other Corvette owners and enthusiasts that are members of the Corvette Action Center forums. Any information used from this How-To section is used at your own risk. Although we do our best to screen and verify the information provided here, the Corvette Action Center is not responsible for any inaccuracy in this How-To section. Always consult your service manual and/or a qualified automotive service technician before conducting any type of automotive repairs or modifications on your own. For further information, please review our Legal Disclaimer.
0 (0)
Article Rating (No Votes)
Rate this article
There are no attachments for this article.
There are no comments for this article. Be the first to post a comment.
Security Code Security Code
Related Articles RSS Feed
