Follow the Corvette Action Center on Twitter!
VetteTube: Premium Entertainment for Corvette Enthusiasts including videos, babes and more!
<< 2010 Corvette Center
2012 Corvette Center >>
2011 Corvette ZR1 Specifications
Print Friendly and PDF
Model Lineup | Overview | Engines | Transmission | Chassis/Suspension | Brakes | Wheels/Tires | Dimensions | Capacities
Model Lineup
Engine
Transmission
6.2L supercharged V-8 (LS9)
Tremec TR6060 six-speed manual
Corvette ZR1
s
s
Key
Standard
s
Back to top
Overview
Model:
Chevrolet Corvette ZR1
Body styles / driveline:
2-door hatchback coupe with fixed roof; rear-wheel drive
Construction:
composite and carbon-fiber body panels, hydroformed aluminum frame with aluminum and magnesium structural and chassis components
Manufacturing location:
Bowling Green, Ky.
Back to top
Engines
6.2L SUPERCHARGED V-8 (LS9)
Displacement (cu in / cc):
376 / 6162
Bore & stroke (in / mm):
4.06 x 3.62 / 103.25 x 92
Block material:
cast aluminum
Cylinder head material:
cast aluminum
Valvetrain:
overhead valve, two valves per cylinder
Fuel delivery:
SFI (sequential fuel injection)
Compression ratio:
9.1:1
Horsepower / kW:
638 / 476 @ 6500*
Torque (lb-ft / Nm):
604 / 819 @ 3800*
Recommended fuel:
premium required
EPA-estimated fuel economy (city / hwy):
14 / 20
Back to top
Transmission
Tremec TR6060 close-ratio six-speed manual
Gear ratios (:1):
First:
2.29
Second:
1.61
Third:
1.21
Fourth:
1.00
Fifth:
0.82
Sixth:
0.68
Reverse:
3.11
Final drive ratio:
3.42
Back to top
Chassis/Suspension
Front:
short/long arm ( SLA) double wishbone, cast aluminum upper and lower control arms, transverse-mounted composite leaf spring, monotube shock absorber
Rear:
Traction control:
electronic traction control; active handling (Magnetic Selective Ride Control)
Back to top
Brakes
Type:
front and rear power-assisted carbon-ceramic disc with 6-piston front and four-piston rear calipers, cross-drilled rotors; ABS std.
Rotor diameter (in / mm):
front: 15.5 / 394
rear: 15 / 380
Brake swept area
(sq in / mm):
front: 355 / 2290
rear: 309 / 1994
Back to top
Wheels/Tires
Wheel size:
front: 19-inch x 10-inch
rear: 20-inch x 12-inch
Tires:
Michelin Pilot Sport 2
front: P285/30ZR19
rear: P335/25ZR20
Back to top
Exterior
Wheelbase (in / mm):
105.7 / 2685
Overall length (in / mm):
176.2 / 4476
Overall width (in / mm):
75.9 / 1929
Overall height (in / mm):
48.7 / 1236
Curb weight (lb / kg):
3333 / 1512
Weight distribution
(% front / rear):
51 / 49
Interior
Seating capacity
2
Interior volume (cu ft / L):
52 / 1475
Headroom (in / mm):
38 / 962
Legroom (in / mm):
43 / 1092
Shoulder room (in / mm):
55 / 1397
Hip room (in / mm):
54 / 1371
Back to top
Capacities
Cargo volume (cu ft / L):
22 / 634
Fuel tank (gal / L):
18 / 68.1
Engine oil (qt / L):
10.5 / 9.9
Back to top
* SAE certified.
2011 CHEVROLET CORVETTE ZR1
Model Lineup
Engine
Transmission
7.0L V-8 (LS7)
6-spd. manual
Corvette Z06
s
s
Key
Standard
s
Back to top
Overview
Models:
Chevrolet Corvette Z06
two-door hatchback coupe with fixed roof; rear-wheel drive
Construction:
Bowling Green, Ky.
Back to top
Engines
7.0L V-8 LS7 (Z06)
427 / 7008
4.125 x 4 / 104.8 x 101.6
Block material:
cast aluminum
cast aluminum
Valvetrain:
Fuel delivery:
Compression ratio:
11.0:1
Horsepower
(hp / kW @ rpm):
505 / 377 @ 6300*
Torque (lb-ft / Nm @ rpm):
470 / 637 @ 4800*
Recommended fuel:
premium required
EPA estimated fuel economy (city / hwy):
15 / 24 (manual)
Back to top
Transmission
six-speed manual
Application:
std.
Gear ratios (:1):
First:
2.66
Second:
1.78
Third:
1.30
Fourth:
1.00
Fifth:
0.74
Sixth:
0.50
Reverse:
2.90
Final drive ratio:
3.42
Back to top
Chassis/Suspension
Front:
short/long arm (SLA) double wishbone, cast aluminum upper and lower control arms, transverse-mounted composite leaf spring, monotube shock absorber; Magnetic Ride Control w/ Z07 pkg.
Rear:
Traction control:
electronic traction control; Active Handling
Back to top
Brakes
Type:
front and rear power-assisted disc with ABS with six-piston front and four-piston rear calipers, cross-drilled rotors; ceramic rotors w/ Z07 pkg.
Rotor diameter x thickness (in / mm):
front: 14 x 1.3 / 355 x 32
rear: 13.4 x 1 / 340 x 26
Brake swept area
(sq in / mm):
front: 309 / 1994
rear: 269 / 1735
Back to top
Wheels/Tires
Wheel size:
front: 18-inch x 9.5-inch (std); 19-inch x 10-inch (w/ Z07 pkg.)
rear: 19-inch x 12-inch (std); 20-inch x 12-inch (w/ Z07 pkg.)
Tires:
front: 275/35ZR18 (std.); 285/30ZR19 (w/ Z07 pkg.)
rear: 325/30ZR19 (std.); 335/25ZR20 (w/ Z07 pkg.)
Back to top
Exterior
105.7 / 2685
175.6 / 4460
75.9 / 1928
48.7 / 1236
3175 / 1440 (Z06)
Weight distribution
(% front / rear):
50 / 50 (Z06)
Interior
Seating capacity
2
52 / 1475
Headroom (in / mm):
38 / 962
Legroom (in / mm):
43 / 1092
55 / 1397
Hip room (in / mm):
54 / 1371
Back to top
Capacities
22 / 634
18 / 68.1
10.5 / 9.9
Back to top
* SAE certified.
Parts/Accessories:
Corvette Central
Reverse Logic
Vetteskins
