Follow the Corvette Action Center on Twitter!
VetteTube: Premium Entertainment for Corvette Enthusiasts including videos, babes and more!
  • Supporting Vendors / Dealers - Advertising - Shop
    << 2010 Corvette Center
    2012 Corvette Center >>
    2011 Corvette Specifications
    Print Friendly and PDF
    Source:  GM Media
    Model Lineup | Overview | Engines | Transmission | Chassis/Suspension | Brakes | Wheels/Tires | Dimensions | Capacities
    Model Lineup
    Engines
    Transmissions
    6.2L V-8 (LS3)
    6-spd. manual
    6-spd. paddle shift automatic
    Corvette coupe
    s
    s
    o
    Corvette convertible
    s
    s
    o
    Corvette Grand Sport coupe*
    s
    s
    o
    Corvette Grand Sport convertible*
    s
    s
    o
    * Includes specific manual transmission ratios and specifc axle ratio with automatic transmission
    Key
    Standard
    s
    Optional
    o
    Back to top
    Overview
    Models:
    Chevrolet Corvette coupe, convertible and Grand Sport coupe, convertible
    Body styles / driveline:
    two-door hatchback coupe with removable roof or converible; rear-wheel drive
    Construction:
    composite body panels, hydroformed steel frame with aluminum and magnesium structural and chassis components
    Manufacturing location:
    Bowling Green, Ky.
    Back to top
    Engines
    6.2L V-8 LS3
    Displacement (cu in / cc):
    376 / 6162
    Bore & stroke (in / mm):
    4.06 x 3.62 / 103.25 x 92
    Block material:
    cast aluminum
    Cylinder head material:
    cast aluminum
    Valvetrain:
    overhead valve, two valves per cylinder
    Fuel delivery:
    SFI (sequential fuel injection)
    Compression ratio:
    10.7:1
    Horsepower
    (hp / kW @ rpm):
    430 / 321 @ 5900* w/ std. exhaust
    436 / 325 @ 5900* w/ opt. exhaust
    Torque
    (lb-ft / Nm @ rpm):
    424 / 575 @ 4600* w/ std. exhaust
    428 / 580 @ 4600* w/ opt. exhaust
    Recommended fuel:
    premium recommended not required
    EPA estimated fuel economy (city / hwy):
    15 / 25 (automatic)
    16 / 26 (manual)
    Back to top
    Transmission
    six-speed manual
    six-speed paddle-shift automatic
    Application:
    std.
    opt.
    Gear ratios (:1):
    First:
    2.66
    4.03
    Second:
    1.78
    2.36
    Third:
    1.30
    1.53
    Fourth:
    1.00
    1.15
    Fifth:
    0.74
    0.85
    Sixth:
    0.50
    0.67
    Reverse:
    2.90
    3.06
    Final drive ratio:
    3.42
    2.56
    Back to top
    Chassis/Suspension
    Front:
    short/long arm ( SLA) double wishbone, cast aluminum upper and lower control arms, transverse-mounted composite leaf spring, monotube shock absorber
    Rear:
    Traction control:
    electronic traction control; Active Handling
    Back to top
    Brakes
    Type:
    front and rear power-assisted disc with ABS
    front and rear power-assisted disc with ABS with six-piston front and four-piston rear calipers, cross-drilled rotors
    Rotor diameter x thickness (in / mm):
    front: 12.8 x 1.26 / 325 x 32 (std.); 13.4 x 1.26 / 340 x 32 (w/ Magnetic Ride Control)
    rear: 12 x 1 / 305 x 26; (std.); 13 x 1 / 330 x 26 (w/ Magnetic Ride Control)
    front: 14 x 1.3 / 355 x 32
    rear: 13.4 x 1 / 340 x 26
    Brake swept area
    (sq in / mm):
    front: 274 / 1768
    rear: 200 / 1290
    front: 309 / 1994
    rear: 269 / 1735
    Back to top
    Wheels/Tires
    Wheel size:
    front: 18-inch x 8.5-inch
    rear: 19-inch x 10-inch
    front: 18-inch x 9.5-inch
    rear: 19-inch x 12-inch
    Tires:
    front: P245/40ZR18
    rear: P285/35ZR19
    front: P275/35ZR18
    rear: P325/30ZR19
    Back to top
    Exterior
    Wheelbase (in / mm):
    105.7 / 2685
    105.7 / 2685
    Overall length (in / mm):
    174.6 / 4435
    175.6 / 4460
    Overall width (in / mm):
    72.6 / 1844
    75.9 / 1928
    Overall height (in / mm):
    49 / 1244
    48.7 / 1236
    Curb weight (lb / kg):
    3208 / 1455 (coupe)
    3221 / 1461 (convertible)
    3311 / 1502 (coupe)
    3289 / 1492 (convertible)
    Weight distribution
    (% front / rear):
    51 / 49
    51 / 49
    Interior
    Seating capacity
    2
    Interior volume (cu ft / L):
    52 / 1475 (all models)
    Headroom (in / mm):
    38 / 962 (all models)
    Legroom (in / mm):
    43 / 1092 (all models)
    Shoulder room (in / mm):
    55 / 1397 (all models)
    Hip room (in / mm):
    54 / 1371 (all models)
    Back to top
    Capacities
    Cargo volume
    (cu ft / L):
    Coupe and Z06: 22 / 634
    Convertible: 11 / 295 (top up); 7.5 / 212 (top down)
    Fuel tank (gal / L):
    18 / 68.1
    Engine oil (qt / L):
    5.5 / 5.2
    Back to top
    * SAE certified.
  • © CORVETTE is a registered trademark of the General Motors Corporation & Chevrolet Motor Division.  Neither Chevrolet Motor Division nor any subsidiaries of GM© shall bear any responsibility for CorvetteActionCenter.com content, comments, or advertising. CorvetteActionCenter.com is independent from GM© and is not affiliated with, sponsored or supported by GM©.  Copyright/trademark/sales mark infringements are not intended, or implied.  All Rights Reserved
