Follow the Corvette Action Center on Twitter!
VetteTube: Premium Entertainment for Corvette Enthusiasts including videos, babes and more!
  • Supporting Vendors / Dealers - Advertising - Shop
    << 2009 Corvette Tech Center
    2011 Corvette Tech Center >>
    2010 Corvette ZR1 Specifications
    Print Friendly and PDF
    2010-03-03
    Source:  General Motors
    Overview
    Model:
    Chevrolet Corvette ZR1
    Body styles / driveline:
    2-door hatchback coupe with fixed roof; rear-wheel drive
    Construction:
    composite and carbon-fiber body panels, hydroformed aluminum frame with aluminum and magnesium structural and chassis components
    Manufacturing location:
    Bowling Green, Ky.
    Engine
    6.2L SUPERCHARGED  V-8 (LS9)
    Displacement (cu in / cc):
    376 / 6162
    Bore & stroke (in / mm):
    4.06 x 3.62 / 103.25 x 92
    Block material:
    cast aluminum
    Cylinder head material:
    cast aluminum
    Valvetrain:
    overhead valve, two valves per cylinder
    Fuel delivery:
    SFI (sequential fuel injection)
    Compression ratio:
    9.1:1
    Horsepower / kW:
    638 / 476 @ 6500*
    Torque (lb-ft / Nm):
    604 / 819 @ 3800*
    Recommended fuel:
    premium required
    EPA-estimated fuel economy (city / hwy):
    14 / 20
    Transmission
    Tremec TR6060 close-ratio six-speed manual
    Gear ratios (:1):
    First:
    2.29
    Second:
    1.61
    Third:
    1.21
    Fourth:
    1.00
    Fifth:
    0.81
    Sixth:
    0.67
    Reverse:
    3.11
    Final drive ratio:
    3.42
    Chassis / Suspension
    Front:
    short/long arm (SLA) double wishbone, cast aluminum upper and lower control arms, transverse-mounted composite leaf spring, monotube shock absorber
    Rear:
    Traction control:
    electronic traction control; active handling (Magnetic Selective Ride Control)
    Brakes
    Type:
    front and rear power-assisted carbon-ceramic disc with 6-piston front and four-piston rear calipers, cross-drilled rotors; ABS std.
    Rotor diameter (in / mm):
    front: 15.5 / 394
    rear: 15 / 380
    Brake swept area (sq in / mm):
    front: 355 / 2290
    rear: 309 / 1994
    Wheels / Tires
    Wheel size:
    front: 19-inch x 10-inch
    rear: 20-inch x 12-inch
    Tires:
    Michelin Pilot Sport 2
    front: P285/30ZR19
    rear: P335/25ZR20
    Exterior
    Wheelbase (in / mm):
    105.7 / 2685
    Overall length (in / mm):
    176.2 / 4476
    Overall width (in / mm):
    75.9 / 1929
    Overall height (in / mm):
    48.7 / 1236
    Curb weight (lb / kg):
    3333 / 1512
    Weight distribution (% front / rear):
    51 / 49
    Interior
    Seating capacity
    2
    Interior volume (cu ft / L):
    52 / 1475 (all models)
    Headroom (in / mm):
    38 / 962 (all models)
    Legroom (in / mm):
    43 / 1092 (all models)
    Shoulder room (in / mm):
    55 / 1397 (all models)
    Hip room (in / mm):
    54 / 1371 (all models)
    Capacities
    Cargo volume (cu ft / L):
    22 / 634
    Fuel tank (gal / L):
    18 / 68.1
    Engine oil (qt / L):
    10.5 / 9.9
    *SAE certified.
    Parts/Accessories:
    Corvette Central
    Reverse Logic
    Vetteskins
  • © CORVETTE is a registered trademark of the General Motors Corporation & Chevrolet Motor Division.  Neither Chevrolet Motor Division nor any subsidiaries of GM© shall bear any responsibility for CorvetteActionCenter.com content, comments, or advertising. CorvetteActionCenter.com is independent from GM© and is not affiliated with, sponsored or supported by GM©.  Copyright/trademark/sales mark infringements are not intended, or implied.  All Rights Reserved
