Bookmark This Page | Recommend This Page | Site Search
Supporting Vendors / Dealers - Supporting Membership - Advertising Information
Share or Bookmark this page
Corvette Action Center Knowledgebase
Knowledgebase Home | Glossary | Favorites | Contact | Login Knowledgebase Home | Glossary | Favorites | Contact | Login
Search the Knowledgebase Browse by Category
1976: Service Bulletin: Heater Hose Clamp Interference with A/C Evaporator Inlet Pipe
Article Details
Last Updated
27th of January, 2007
Subject: Heater Hose Clamp Interference with A/C Evaporator Inlet Pipe
Model and Year: 1976 Corvette with A/C
Source: Chevrolet Dealer Service Technical Bulletin
Bulletin Number: 76-T-43, Section Ia
Date: Nov. 1976
TO:  ALL CHEVROLET DEALERS
On some 1976 Corvettes, the heater hose clamp screw may rub against the evaporator inlet refrigeration pipe.  This condition could cause a hole being worn through the evaporator pipe resulting in a loss of freon.  For 1977 production models, this condition has been corrected by lengthening the heater hose.
1976 Corvettes, when serviced, should be checked for this condition.  If interference is evident, teh following changes should be made:
  1. Loosen hose clamp and rotate to provide maximum clearance to the evaporator pipe.
  2. Insert a section of slit rubber hose over the evaporator inlet pipe in the area of the hose clamp. (See Figure 1)
  3. In the event the clamp screw has worn through and a loss of freon has taken place, it will be necessary to replace the evaporator core.
Recommended time for correction .3 hours.
Chevrolet Motor Division
General Motors Corporation
General Motors bulletins are intended for use by professional technicians, not a "do-it-yourselfer". They are written to inform those technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions and know-how to do a job properly and safely. If a condition is described, do not assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See a General Motors dealer servicing your brand of General Motors vehicle for information on whether your vehicle may benefit from the information.
© Copyright General Motors Corporation. All Rights Reserved
Visitor Comments
No visitor comments posted. Post a comment
Post Comment for "1976: Service Bulletin: Heater Hose Clamp Interference with A/C Evaporator Inlet Pipe"
NOTE:  Please do not ask technical questions here as you will not get a response. To ask questions, please join our forums and post your question there.
To post a comment for this article, simply complete the form below. Fields marked with an asterisk are required.
   Your Name:
   Email Address:
* Your Comment:
* Enter the code below:
No related articles were found.
No attachments were found.
Continue
