Supporting Vendors / Dealers - Supporting Membership - Advertising Information
Corvette Action Center Knowledgebase
Print Friendly and PDF
Knowledgebase Home | Glossary | Favorites | Contact | Login Knowledgebase Home | Glossary | Favorites | Contact | Login
Search the Knowledgebase Browse by Category
1959: Chevrolet Service News: Drive Line Vibration - Corvette
Article Details
Last Updated
9th of February, 2012
Source:   Chevrolet Service News
Page:  4
Date:  July-August, 1959
Subject:   Drive Line Vibration -- Corvette
If excessive drive line vibration is encountered on a 1959 Corvette it is probably due to excessive rear C-joint angle.  This vibration can be eliminated by installing either ra 2 or 3 degree rear axle shim.  The shim should be installed between the rear axle pads and springs, on both sides, with the thick edge to the front.
The minimum angle of the rear U-joint is 7 ½ degrees.  If this angle is reduced to less than 7 ½ degrees, interference will result in the full bump position.
Measurements of the propeller shaft and pinion nose angle may be accomplished as follows:
  1. Load vehicle until distance between the axle housing and the frame rail pick-up (metal to metal) is 4 ½".  Retaining the vehicle in this position, the angle of the propeller shaft and pinion nose can be measured as shown in 1958 Passenger Car Shop Manual.
  2. The radius control rods should be disconnected before installing the shim.  Before re-attaching the radius control rods, elongate the radius rod frame mounting hole ¼" rearward if necessary to eliminate any interference between the radius control rods attaching bolt and mounting bracket.
Shims #3722797 (2 deg), #3744488 (3 deg), or their equivalent may be utilized.  The locating tab on the above shims should be removed to allow the shim to lie flat.
© Copyright General Motors Corporation. All Rights Reserved
Visitor Comments
No visitor comments posted. Post a comment
Post Comment for "1959: Chevrolet Service News: Drive Line Vibration - Corvette"
NOTE:  Please do not ask technical questions here as you will not get a response. To ask questions, please join our forums and post your question there.
To post a comment for this article, simply complete the form below. Fields marked with an asterisk are required.
   Your Name:
   Email Address:
* Your Comment:
* Enter the code below:
No related articles were found.
No attachments were found.
Continue
