Bookmark This Page | Recommend This Page | Site Search
Supporting Vendors / Dealers - Supporting Membership - Advertising Information
Share or Bookmark this page
Corvette Action Center Knowledgebase
Knowledgebase Home | Glossary | Favorites | Contact | Login Knowledgebase Home | Glossary | Favorites | Contact | Login
Search the Knowledgebase Browse by Category
Technical Article: The Care and Cleaning of Stainless Steel
Article Details
Last Updated
19th of March, 2007
Cleanliness and stainless steel are closely related and, in many applications, each is dependent upon the other.  In the handling of food, chemicals, pharmaceuticals and in the use of stainess steel as a construction material (roofs, wall panels, entry ways, signs, etc.), stainless steel provides the degree of corrosion resistance that is necessary to prevent product contamination or surface rusting.  However, stainless steel performs best when clean -- cleanliness is essentially for maximum resistance to corrosion.
This handbook describes various practics for cleaning stainless steel during manufacture and in use.  This includes methods for removing free-iron contamination on stainless steel surfaces that may have been picked up from metalworking tools; and for removing general accumulation of dirt, grime and surface stains that occur during normal handling and exposure to the elements.
This is a 7-page PDF document that is linked below.
Visitor Comments
No visitor comments posted. Post a comment
Post Comment for "Technical Article: The Care and Cleaning of Stainless Steel"
NOTE:  Please do not ask technical questions here as you will not get a response. To ask questions, please join our forums and post your question there.
To post a comment for this article, simply complete the form below. Fields marked with an asterisk are required.
   Your Name:
   Email Address:
* Your Comment:
* Enter the code below:
Continue
