Bookmark This Page | Recommend This Page | Site Search
Supporting Vendors / Dealers - Supporting Membership - Advertising Information
Share or Bookmark this page
Corvette Action Center Knowledgebase
Knowledgebase Home | Glossary | Favorites | Contact | Login Knowledgebase Home | Glossary | Favorites | Contact | Login
Search the Knowledgebase Browse by Category
1966: Service News: Air Conditioning Thermostatic Expansion Valve Replacement
Article Details
Last Updated
26th of January, 2007
Model Year: 1966
Subject: Air Conditioning Termostatic Expansion Valve Replace - 1966 Corvette
Source: Chevrolet Service News
Date: August, 1966
The service procedure for replacing the expansion valve on the 1966 Corvette is outlined below. This procedure is more detailed and supercedes the one listed on page 1A-57 of the 1966 Chassis Service Manual.
  1. Purge system of refrigerent.
  2. Drain cooling system and remove radiator supply tank.
  3. Disconnect heater hoses from heater core.
  4. Disconnect power element bulb.
  5. Remove expansion valve hold down strap.
  6. Remove equalizer line from suction throttling valve.
  7. Disconnect expansion valve inlet and outlet connections and remove valve.
  8. Install new thermostatic expansion valve by reversing removal procedure.
  9. Evacuate and charge system.
Visitor Comments
No visitor comments posted. Post a comment
Post Comment for "1966: Service News: Air Conditioning Thermostatic Expansion Valve Replacement"
NOTE:  Please do not ask technical questions here as you will not get a response. To ask questions, please join our forums and post your question there.
To post a comment for this article, simply complete the form below. Fields marked with an asterisk are required.
   Your Name:
   Email Address:
* Your Comment:
* Enter the code below:
No attachments were found.
Continue
