Supporting Vendors / Dealers - Supporting Membership - Advertising Information
Corvette Action Center Knowledgebase
Print Friendly and PDF
Knowledgebase Home | Glossary | Favorites | Contact | Login Knowledgebase Home | Glossary | Favorites | Contact | Login
Search the Knowledgebase Browse by Category
1955: Service Bulletin: New Gasoline Gauge Dash Unit
Article Details
Last Updated
25th of January, 2007
Subject: New Gasoline Gauge Dash Unit
Model and Year: 1955 Passenger Cars
Source: Chevrolet Technical Service Bulletin
Bulletin Number: DR #195, Section XII
Date: February 8, 1955
TO:  ALL CHEVROLET DEALERS
In cases where the Gaoline Gauge in the instrument cluster reads 3/4 full when the tank is completely full it may be the result of a change in calibration of the gauge due to a feed back through the ignition switch.
A new Gauge which is unaffectged by the above condition went into production about 1-14-55, and is now available in Parts Stock.
PARTS DATA
Description:  Gas Gauge Dash Unit
New Part No:  1518407
Old Part No:  1518152
All of the early type gagues in Parts Stock are being returned to the source for correction.
As a means of identification, both coils on the early gauge are red.  The Left Hand Coil on the new gauge is green.
Visitor Comments
No visitor comments posted. Post a comment
Post Comment for "1955: Service Bulletin: New Gasoline Gauge Dash Unit"
NOTE:  Please do not ask technical questions here as you will not get a response. To ask questions, please join our forums and post your question there.
To post a comment for this article, simply complete the form below. Fields marked with an asterisk are required.
   Your Name:
   Email Address:
* Your Comment:
* Enter the code below:
No attachments were found.
Continue
