Supporting Vendors / Dealers - Supporting Membership - Advertising Information
Corvette Action Center Knowledgebase
Print Friendly and PDF
Knowledgebase Home | Glossary | Favorites | Contact | Login Knowledgebase Home | Glossary | Favorites | Contact | Login
Search the Knowledgebase Browse by Category
2005: Service Information: HVAC Module Service
Article Details
Last Updated
28th of January, 2007
This information applies to the 2004 Cadillac XLR and the 2005 Chevrolet Corvette and newer.
Use special care when removing or installing the HVAC module for service. The HVAC module is seated between a non-removable upper and lower tie bar
(fig. 11 - attached). The HVAC module must be partially disassembled before removal and installation (fig. 12 - attached).
Refer to SI 2000 to obtain the service procedure for correctly removing and installing the HVAC module. Failure to do could result in damage to the HVAC module.
- Thanks to Chris Semanisin, GM TechLink, September 2004
General Motors bulletins are intended for use by professional technicians, not a "do-it-yourselfer". They are written to inform those technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions and know-how to do a job properly and safely. If a condition is described, do not assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See a General Motors dealer servicing your brand of General Motors vehicle for information on whether your vehicle may benefit from the information.
© Copyright General Motors Corporation. All Rights Reserved
Visitor Comments
No visitor comments posted. Post a comment
Post Comment for "2005: Service Information: HVAC Module Service"
NOTE:  Please do not ask technical questions here as you will not get a response. To ask questions, please join our forums and post your question there.
To post a comment for this article, simply complete the form below. Fields marked with an asterisk are required.
   Your Name:
   Email Address:
* Your Comment:
* Enter the code below:
Continue
